This is a documentation subpage for Modèle:Infobox Machine.It contains usage information, categories, and other content that is not part of the original template page.
- Template Usage
The Item Infobox template is used for any item that is not considered a weapon, space suit or clothing. Copy and paste the following code into the top of an article, filling all known fields. Leave all the unknown fields empty and they will not appear on the infobox.
- Example
{{Infobox Item | Name = | Image = | Manufacturer = | Type = | Mass = | Usage = | UEC Cost = | REC Cost = | Range = | Whitley Rating = | Ammo Count = | Rate = | Overheat Time = | Cool Time = | Power Drain = | IR Signature = }}
- Example Input
