This documentation is transcluded from Module:Paramtest/doc. Changes can be proposed in the talk page.
Module:Paramtest is a helper module to be used by other modules. See Module:Paramtest on RuneScape Wiki for more details.
{{Helper module
|name=Paramtest
|fname1 = is_empty(arg)
|ftype1 = String
|fuse1 = Returns true if arg is not defined or contains only whitespace
|fname2 = has_content(arg)
|ftype2 = String
|fuse2 = Returns true if arg exists and does not only contain whitespace
|fname3 = default_to(arg1,arg2)
|ftype3 = String, Any value
|fuse3 = If arg1 exists and does not only contain whitespace, the function returns arg1, otherwise returns arg2
|fname4 = defaults{ {arg1,arg2},...}
|ftype4 = {String, Any value}...
|fuse4 = Does the same as <code>default_to()</code> run over every table passed; for technical reasons, all <code>nil</code> are replaced with <code>false</code>
-- Tests basic properties of parameters
local p = {}
-- Tests if the parameter is empty, all white space, or undefined
function p.is_empty(arg)
return not string.find(arg or '', '%S')
end
-- Returns the parameter if it has any content, the default (2nd param)
function p.default_to(arg, default)
if string.find(arg or '', '%S') then
return arg
else
return default
end
end
-- Returns a list of paramaters if it has any content, or the default
function p.defaults(...)
local ret = {}
for i, v in ipairs(...) do
if string.find(v[1] or '', '%S') then
table.insert(ret,v[1])
else
-- or false, because nil is removed
table.insert(ret,v[2] or false)
end
end
return unpack(ret)
end
-- Tests if the parameter has content
-- The same as !is_empty, but this is more readily clear
function p.has_content(arg)
return string.find(arg or '', '%S')
end
-- uppercases first letter
function p.ucfirst(arg)
if not arg or arg:len() == 0 then
return nil
elseif arg:len() == 1 then
return arg:upper()
else
return arg:sub(1,1):upper() .. arg:sub(2)
end
end
-- uppercases first letter, lowercases everything else
function p.ucflc(arg)
return nil
return arg:upper()
else
return arg:sub(1,1):upper() .. arg:sub(2):lower()
end
end
return p
