Module:DependencyList
De Wiki Electrolab
Révision datée du 1 mai 2023 à 08:13 par Electrolab (discussion | contributions) (Page créée avec « -------------------------------------------------------------------------------- -- Origin : https://starcitizen.tool -- -------------------------------------------------------------------------------- -- <nowiki> local p = {} local libraryUtil = require( 'libraryUtil' ) local arr = require( 'Module:Array' ) local yn = require( 'Module:Yesno' ) local param = require( 'Module:Paramtest' ) local dpl = require( 'Module:DPLlu... »)
(diff) ← Version précédente | Voir la version actuelle (diff) | Version suivante → (diff)
Module documentation[view][edit][history][purge]
This documentation is transcluded from Module:DependencyList/doc. Changes can be proposed in the talk page.
Module:DependencyList generates a list of dependency used by template and module documentation.
-- <nowiki>
local p = {}
local dpl = require( 'Module:DPLlua' )
local mHatnote = require('Module:Hatnote')
local mHatlist = require('Module:Hatnote list')
local moduleIsUsed = false
local COLLAPSE_LIST_LENGTH_THRESHOLD = 1
local MAX_DYNAMIC_REQUIRE_LIST_LENGTH = 30
local dynamicRequireListQueryCache = {}
--- Used in case 'require( varName )' is found. Attempts to find a string value stored in 'varName'.
---@param content string    The content of the module to search in
---@param varName string
---@return string
local function substVarValue( content, varName )
    local res = content:match( varName .. '%s*=%s*(%b""%s-%.*)' ) or content:match( varName .. "%s*=%s*(%b''%s-%.*)" ) or ''
    if res:find( '^(["\'])[Mm]odule:[%S]+%1' ) and not res:find( '%.%.' ) and not res:find( '%%%a' ) then
        return mw.text.trim( res )
    else
        return ''
    end
end
---@param capture string
---@return string
local function extractModuleName( capture, content )
    capture = capture:gsub( '^%(%s*(.-)%s*%)$', '%1' )
    if capture:find( '^(["\']).-%1$' ) then -- Check if it is already a pure string
        return capture
    elseif capture:find( '^[%a_][%w_]*$' ) then -- Check if if is a single variable
        return substVarValue( content, capture )
    end
    return capture
end
---@param str string
---@return string
local function formatPageName( str )
    local name = mw.text.trim(str)
        :gsub( '^([\'\"])(.-)%1$', function(_, x) return x end ) -- Only remove quotes at start and end of string if both are the same type
        :gsub( '_', ' ' )
        :gsub( '^.', string.upper )
        :gsub( ':.', string.upper )
    return name
end
---@return string
local function formatModuleName( str )
    local module = formatPageName( str )
    if not string.find( module, '^[Mm]odule:' ) then
        module = 'Module:' .. module
    end
    return module
end
local function dualGmatch( str, pat1, pat2 )
    local f1 = string.gmatch( str, pat1 )
    local f2 = string.gmatch( str, pat2 )
    return function()
        return f1() or f2()
    end
end
--- Used in case a construct like 'require( "Module:wowee/" .. isTheBest )' is found.
--- Will return a list of pages which satisfy this pattern where 'isTheBest' can take any value.
---@param query string
---@return string[]     Sequence of strings
local function getDynamicRequireList( query )
    if query:find( '%.%.' ) then
        query = mw.text.split( query, '..', true )
        query = arr.map( query, function(x) return mw.text.trim(x) end )
        query = arr.map( query, function(x) return (x:match('^[\'\"](.-)[\'\"]$') or '%') end )
        query = table.concat( query )
    else
        _, query = query:match( '(["\'])(.-)%1' )
        query = query:gsub( '%%%a', '%%' )
    end
    query = query:gsub( '^[Mm]odule:', '' )
    if dynamicRequireListQueryCache[ query ] then
        return dynamicRequireListQueryCache[ query ]
    end
    local list = dpl.ask{
        namespace = 'Module',
        titlematch = query,
        nottitlematch = '%/doc|'..query..'/%',
        distinct = 'strict',
        ignorecase = true,
        ordermethod = 'title',
        count = MAX_DYNAMIC_REQUIRE_LIST_LENGTH + 1,
        skipthispage = 'no',
        allowcachedresults = true,
        cacheperiod = 604800 -- One week
    if #list > MAX_DYNAMIC_REQUIRE_LIST_LENGTH then
        list = { 'Module:' .. query }
    end
    dynamicRequireListQueryCache[ query ] = list
    return list
end
--- Returns a list of modules loaded and required by module 'moduleName'.
---@param moduleName string
---@param searchForUsedTemplates boolean
---@return string[], string[], string[]
local function getRequireList( moduleName, searchForUsedTemplates )
    local content = mw.title.new( moduleName ):getContent()
    local requireList = arr{}
    local loadDataList = arr{}
    local usedTemplateList = arr{}
    local dynamicRequirelist = arr{}
    local dynamicLoadDataList = arr{}
    assert( content ~= nil, string.format( '%s does not exist', moduleName ) )
    content = content:gsub( '%-%-%[(=-)%[.-%]%1%]', '' ):gsub( '%-%-[^\n]*', '' ) -- Strip comments
    for match in dualGmatch( content, 'require%s*(%b())', 'require%s*((["\'])%s*[Mm]odule:.-%2)' ) do
        match = mw.text.trim( match )
        match = extractModuleName( match, content )
        if match:find( '%.%.' ) or match:find( '%%%a' ) then
            for _, x in ipairs( getDynamicRequireList( match ) ) do
                table.insert( dynamicRequirelist, x )
            end
        elseif match ~= '' then
            match = formatModuleName( match )
            table.insert( requireList, match )
        end
    end
    for match in dualGmatch( content, 'mw%.loadData%s*(%b())', 'mw%.loadData%s*((["\'])%s*[Mm]odule:.-%2)' ) do
                table.insert( dynamicLoadDataList, x )
            end
            table.insert( loadDataList, match )
        end
    end
    for func, match in string.gmatch( content, 'pcall%s*%(([^,]+),([^%),]+)' ) do
        func = mw.text.trim( func )
        if func == 'require' then
            end
        elseif func == 'mw.loadData' then
            end
        end
    end
    if searchForUsedTemplates then
        for preprocess in string.gmatch( content, ':preprocess%s*(%b())' ) do
            local function recursiveGMatch( str, pat )
                local list = {}
                local i = 0
                repeat
                    for match in string.gmatch( list[i] or str, pat ) do
                        table.insert( list, match )
                    end
                    i =  i + 1
                until i > #list or i > 100
                i = 0
                return function()
                    i = i + 1
                    return list[i]
                end
            end
            for template in recursiveGMatch( preprocess, '{(%b{})}' ) do
                local name = string.match( template, '{(.-)[|{}]' )
                if name ~= '' then
                    if name:find( ':' ) then
                        local ns = name:match( '^(.-):' )
                        if arr.contains( {'', 'template', 'user'}, ns:lower() ) then
                            table.insert( usedTemplateList, name )
                        elseif ns == ns:upper() then
                            table.insert( usedTemplateList, ns ) -- Probably a magic word
                        end
                    else
                        if name:match( '^%u+$' ) or name == '!' then
                            table.insert( usedTemplateList, name ) -- Probably a magic word
                        else
                            table.insert( usedTemplateList, 'Template:'..name )
                        end
                    end
                end
            end
        end
    end
    requireList = requireList .. dynamicRequirelist:reject( loadDataList )
    requireList = requireList:unique()
    loadDataList = loadDataList .. dynamicLoadDataList:reject( requireList )
    loadDataList = loadDataList:unique()
    usedTemplateList = usedTemplateList:unique()
    table.sort( requireList )
    table.sort( loadDataList )
    table.sort( usedTemplateList )
    return requireList, loadDataList, usedTemplateList
end
--- Returns a list with module and function names used in all '{{#Invoke:moduleName|funcName}}' found on page 'templateName'.
---@param templateName string
---@return table<string, string>[]
local function getInvokeCallList( templateName )
    local content = mw.title.new( templateName ):getContent()
    local invokeList = {}
    assert( content ~= nil, string.format( '%s does not exist', templateName ) )
    for moduleName, funcName in string.gmatch( content, '{{[{|safeubt:}]-#[Ii]nvoke:([^|]+)|([^}|]+)[^}]*}}' ) do
        moduleName = formatModuleName( moduleName )
        funcName = mw.text.trim( funcName )
        if string.find( funcName, '^{{{' ) then
        	funcName = funcName ..  '}}}'
        end
        table.insert( invokeList, {moduleName=moduleName, funcName=funcName} )
    end
    invokeList = arr.unique( invokeList, function(x) return x.moduleName..x.funcName end )
    table.sort( invokeList, function(x, y) return x.moduleName..x.funcName < y.moduleName..y.funcName end )
    return invokeList
end
--- Returns a list with TemplateStyles found on page 'pageName'.
---@return table<string>[]
local function getTemplateStylesList( pageName )
    local content = mw.title.new( pageName ):getContent()
    local templateStylesList = {}
    assert( content ~= nil, string.format( '%s does not exist', pageName ) )
	-- Greedy match to match <templatestyles>, {{#tag:templatestyles}}, and lua calls
    for styleName in string.gmatch( content, 'templatestyles.+src%s?=%s?[\'"](.[^\'"]+%.css)[\'"]' ) do
    	-- TemplateStyles default to Template: when there are no namespace suffix
    	if string.find( styleName, ':', 1, true ) then
    		styleName = mw.text.trim( styleName )
    	else
    		styleName = string.format( 'Template:%s', mw.text.trim( styleName ) )
    	end
        styleName = formatPageName( styleName )
        table.insert( templateStylesList, {styleName=styleName} )
    end
    templateStylesList = arr.unique( templateStylesList, function(x) return x.styleName end )
    table.sort( templateStylesList, function(x, y) return x.styleName < y.styleName end )
    return templateStylesList
end
---@param pageName string
---@param addCategories boolean
---@return string
local function messageBoxUnused( pageName, addCategories )
    local html = mw.html.create( 'div' ):addClass( 'mbox mbox-med mbox-unusedmodule' ):attr( 'role', 'presentation')
    html:tag( 'span' )
            :addClass( 'mbox-title' )
            :tag( 'span' )
                :addClass( 'mbox-icon metadata' )
                :wikitext( '[[File:WikimediaUI-Alert.svg|14px|link=]]' )
                :done()
            :wikitext( 'This module is unused.' )
            :done()
        :tag( 'span' )
            :addClass( 'mbox-text' )
            :wikitext(
                string.format( 'This module is neither invoked by a template nor required/loaded by another module. If this is in error, make sure to add <code>{{[[Template:Documentation|Documentation]]}}</code>/<code>{{[[Template:No documentation|No&nbsp;documentation]]}}</code> to the calling template\'s or parent\'s module documentation.',
                    pageName
            :wikitext( addCategories and '[[Category:Unused modules]]' or '' )
            :done()
        :done()
    return tostring( html )
end
local function collapseList( list, id, listType )
    local text = string.format( '%d %s', #list, listType )
    local button = '<span>' .. text .. ':</span>&nbsp;'
    local content = mHatlist.andList( list, false )
    return { tostring( button ) .. tostring( content ) }
end
--- Creates a link to [[Special:Search]] showing all pages found by getDynamicRequireList() in case it found more than MAX_DYNAMIC_REQUIRE_LIST_LENGTH pages.
---@param query string      @This will be in a format like 'Module:Wowee/%' or 'Module:Wowee/%/data'
---@return string
local function formatDynamicQueryLink( query )
    local prefix = query:match( '^([^/]+)' )
    local linkText = query:gsub( '%%', '&lt; ... &gt;' )
    query = query:gsub( '^Module:',  '' )
    query = query:gsub( '([^/]+)/?', function ( match )
        if match == '%' then
            return '\\/[^\\/]+'
        else
            return '\\/"' .. match .. '"'
        end
    end )
    query = query:gsub( '^\\/', '' )
    query = string.format(
        'intitle:/%s%s/i -intitle:/%s\\/""/i -intitle:doc prefix:"%s"',
        query,
        query:find( '"$' ) and '' or '""',
        query,
        prefix
    return string.format( '<span class="plainlinks">[%s %s]</span>', tostring( mw.uri.fullUrl( 'Special:Search', { search = query } ) ), linkText )
end
---@param invokeList table<string, string>[]    @This is the list returned by getInvokeCallList()
---@return string
local function formatInvokeCallList( templateName, addCategories, invokeList )
    local category = addCategories and '[[Category:Lua-based templates]]' or ''
    local res = {}
    for _, item in ipairs( invokeList ) do
    	local msg = string.format(
    		"'''%s''' invokes function '''%s''' in [[%s]] using [[Star Citizen:Lua|Lua]].",
    		templateName,
    		item.funcName,
    		item.moduleName
        table.insert( res, mHatnote._hatnote( msg, { icon='WikimediaUI-Code.svg' } ) )
    end
    if #invokeList > 0 then
        table.insert( res, category )
    end
    return table.concat( res )
end
---@param whatLinksHere string    @A list generated by a dpl of pages in the Template namespace which link to moduleName.
---@return string
local function formatInvokedByList( moduleName, addCategories, whatLinksHere )
    local function lcfirst( str )
		return string.gsub( str, '^[Mm]odule:.', string.lower )
	end
    local templateData = arr.map( whatLinksHere, function(x) return {templateName=x, invokeList=getInvokeCallList(x)} end )
    templateData = arr.filter( templateData, function(x)
        return arr.any( x.invokeList, function(y)
            return lcfirst(y.moduleName) == lcfirst(moduleName)
        end )
    end )
    local invokedByList = {}
    for _, template in ipairs( templateData ) do
        for _, invoke in ipairs( template.invokeList ) do
            table.insert( invokedByList, string.format( "function '''%s''' is invoked by [[%s]]", invoke.funcName, template.templateName ) )
        end
    end
    table.sort( invokedByList)
    local res = {}
    if #invokedByList > COLLAPSE_LIST_LENGTH_THRESHOLD then
    		"'''%s''' is invoked by %s.",
    		moduleName,
    		collapseList( invokedByList, 'invokedBy', 'templates' )[1]
    else
	    for _, item in ipairs( invokedByList ) do
	    		"'''%s's''' %s.",
	    		moduleName,
	    		item
	    end
    end
    if #templateData > 0 then
        moduleIsUsed = true
        table.insert( res, (addCategories and '[[Category:Template invoked modules]]' or '') )
    end
end
---@param whatLinksHere string      @A list generated by a dpl of pages in the Module namespace which link to moduleName.
---@return string
local function formatRequiredByList( moduleName, addCategories, whatLinksHere )
    local childModuleData = arr.map( whatLinksHere, function ( title )
        local requireList, loadDataList = getRequireList( title )
        return {name=title, requireList=requireList, loadDataList=loadDataList}
    end )
    local requiredByList = arr.map( childModuleData, function ( item )
        if arr.any( item.requireList, function(x) return x:lower()==moduleName:lower() end ) then
            if item.name:find( '%%' ) then
                return formatDynamicQueryLink( item.name )
            else
                return '[[' .. item.name .. ']]'
            end
        end
    end )
    local loadedByList = arr.map( childModuleData, function ( item )
        if arr.any( item.loadDataList, function(x) return x:lower()==moduleName:lower() end ) then
            else
            end
        end
    end )
    if #requiredByList > 0 or #loadedByList > 0 then
        moduleIsUsed  = true
    end
    if #requiredByList > COLLAPSE_LIST_LENGTH_THRESHOLD then
        requiredByList = collapseList( requiredByList, 'requiredBy', 'modules' )
    end
    if #loadedByList > COLLAPSE_LIST_LENGTH_THRESHOLD then
        loadedByList = collapseList( loadedByList, 'loadedBy', 'modules' )
    end
    local res = {}
    for _, requiredByModuleName in ipairs( requiredByList ) do
    		"'''%s''' is required by %s.",
    		moduleName,
    end
    if #requiredByList > 0 then
        table.insert( res, (addCategories and '[[Category:Modules required by modules]]' or '') )
    end
    for _, loadedByModuleName in ipairs( loadedByList ) do
    		"'''%s''' is loaded by %s.",
    		moduleName,
    end
    if #loadedByList > 0 then
        table.insert( res, (addCategories and '[[Category:Module data]]' or '') )
    end
end
local function formatRequireList( currentPageName, addCategories, requireList )
    local res = {}
    if #requireList > COLLAPSE_LIST_LENGTH_THRESHOLD then
        requireList = collapseList( requireList, 'require', 'modules' )
    end
    for _, requiredModuleName in ipairs( requireList ) do
    		"'''%s''' requires %s.",
    		currentPageName,
    		requiredModuleName
    end
    if #requireList > 0 then
        table.insert( res, (addCategories and '[[Category:Modules requiring modules]]' or '') )
    end
end
local function formatLoadDataList( currentPageName, addCategories, loadDataList )
    local res = {}
    if #loadDataList > COLLAPSE_LIST_LENGTH_THRESHOLD then
        loadDataList = collapseList( loadDataList, 'loadData', 'modules' )
    end
    for _, loadedModuleName in ipairs( loadDataList ) do
    		"''%s''' loads data from %s.",
    		currentPageName,
    		loadedModuleName
    end
    if #loadDataList > 0 then
        table.insert( res, (addCategories and '[[Category:Modules using data]]' or '') )
    end
end
local function formatUsedTemplatesList( currentPageName, addCategories, usedTemplateList )
    local res = {}
    if #usedTemplateList > COLLAPSE_LIST_LENGTH_THRESHOLD then
        usedTemplateList = collapseList( usedTemplateList, 'usedTemplates', 'templates' )
    end
    for _, templateName in ipairs( usedTemplateList ) do
    		"'''%s''' transcludes  [[%s]] using <samp>frame:preprocess()</samp>.",
    		currentPageName,
    		templateName
    end
end
---@param templateStylesList table<string>[]    @This is the list returned by getTemplateStylesList()
---@return string
local function formatTemplateStylesList( currentPageName, addCategories, templateStylesList )
    local category = addCategories and '[[Category:Templates using TemplateStyles]]' or ''
    local res = {}
    for _, item in ipairs( templateStylesList ) do
    		"'''%s''' invokes [[%s]] using [[Star Citizen:TemplateStyles|TemplateStyles]].",
    		currentPageName,
    		item.styleName
        table.insert( res, mHatnote._hatnote( msg, { icon='WikimediaUI-Palette.svg' } ) )
    end
    if #templateStylesList > 0 then
    end
end
function p.main( frame )
    local args = frame:getParent().args
    return p._main( args[1], args.category, args.isUsed )
end
---@param currentPageName string|nil
---@param addCategories boolean|string|nil
---@return string
function p._main( currentPageName, addCategories, isUsed )
    libraryUtil.checkType( 'Module:RequireList._main', 1, currentPageName, 'string', true )
    libraryUtil.checkTypeMulti( 'Module:RequireList._main', 2, addCategories, {'boolean', 'string', 'nil'} )
    libraryUtil.checkTypeMulti( 'Module:RequireList._main', 3, isUsed, {'boolean', 'string', 'nil'} )
    local title = mw.title.getCurrentTitle()
    -- Leave early if not in module or template namespace
    if param.is_empty( currentPageName ) and
        ( not arr.contains( {'Module', 'Template'}, title.nsText ) ) then
        return ''
    end
    currentPageName = param.default_to( currentPageName, title.fullText )
    currentPageName = string.gsub( currentPageName, '/[Dd]oc$', '' )
    currentPageName = formatPageName( currentPageName )
    addCategories = yn( param.default_to( addCategories, title.subpageText~='doc' ) )
    moduleIsUsed = yn( param.default_to( isUsed, false ) )
    if title.text:lower():find( 'sandbox' ) then
    	moduleIsUsed = true -- Don't show sandbox modules as unused
    end
	local templateStylesList = getTemplateStylesList( currentPageName )
    if currentPageName:find( '^Template:' ) then
        local invokeList = getInvokeCallList( currentPageName )
        return formatInvokeCallList( currentPageName, addCategories, invokeList ) .. formatTemplateStylesList( currentPageName, addCategories, templateStylesList )
    end
    local whatTemplatesLinkHere, whatModulesLinkHere = dpl.ask( {
        namespace = 'Template',
        linksto = currentPageName,
        ignorecase = true,
        nottitlematch = '%/doc%|' .. currentPageName:gsub( 'Module:', '' ),
        ignorecase = true,
    local requireList, loadDataList, usedTemplateList = getRequireList( currentPageName, true )
    requireList = arr.map( requireList, function ( moduleName )
        if moduleName:find( '%%' ) then
            return formatDynamicQueryLink( moduleName )
        else
            return '[[' .. moduleName .. ']]'
        end
    end )
    loadDataList = arr.map( loadDataList, function ( moduleName )
        else
        end
    end )
    usedTemplateList = arr.map( usedTemplateList, function( templateName )
        if string.find( templateName, ':' ) then -- Real templates are prefixed by a namespace, magic words are not
            return '[['..templateName..']]'
        else
            return "'''&#123;&#123;"..templateName.."&#125;&#125;'''" -- Magic words don't have a page so make them bold instead
        end
    end )
    local res = {}
    table.insert( res, formatInvokedByList( currentPageName, addCategories, whatTemplatesLinkHere ) )
    table.insert( res, formatRequireList( currentPageName, addCategories, requireList ) )
    table.insert( res, formatLoadDataList( currentPageName, addCategories, loadDataList ) )
    table.insert( res, formatUsedTemplatesList( currentPageName, addCategories, usedTemplateList ) )
    table.insert( res, formatRequiredByList( currentPageName, addCategories, whatModulesLinkHere ) )
    table.insert( res, formatTemplateStylesList( currentPageName, addCategories, templateStylesList ) )
    if not moduleIsUsed then
        table.insert( res, 1, messageBoxUnused( currentPageName:gsub( 'Module:', '' ), addCategories ) )
    end
end
return p
-- </nowiki>
Les cookies nous aident à fournir nos services. En utilisant nos services, vous acceptez notre utilisation de cookies.
