Modèle:Documentation
De Wiki Electrolab
Révision datée du 1 mai 2023 à 11:39 par Electrolab (discussion | contributions) (Page créée avec « <includeonly>{{#invoke:Documentation|doc}}__NOEDITSECTION__{{#seo: |type = website |description = {{FULLPAGENAME}} is a template page used on the Star Citizen Wiki. Templates are pages that are embedded (transcluded) into other pages to allow for the repetition of information. |site_name = Star Citizen Wiki |locale = {{PAGELANGUAGE}} }}</includeonly><noinclude>{{/doc}}</noinclude> »)
(diff) ← Version précédente | Voir la version actuelle (diff) | Version suivante → (diff)
Template documentation[view][edit][history][purge]
This documentation is transcluded from Modèle:Documentation/doc. Changes can be proposed in the talk page.
The documentation template is transcluded in the template/module documentation. This template should only be used on subpages titled "doc".
Usage
Place {{documentation}} at the top of the documentation page.
If the page to be documented is a subpage, use {{documentation|<pagename of page to be documented>}} at the top of the documentation page. For example, Template:Foo/bar's documentation page would use {{documentation|<Template:Foo/bar>}}.
The template will attempt to auto detect and link {{#Invoke:}} calls on template documentations or the require()/mw.loadData() depedency list on module documentations. If you want to supress the auto generated dependency list, use {{documentation}}
Note
This template links to a /doc that may appear useless, however, it exists in order to link navboxes and userboxes to their base template's documentation.
TemplateData
Paramètres du modèle
ParamètreDescriptionTypeÉtat
Aucun paramètre spécifié
Les cookies nous aident à fournir nos services. En utilisant nos services, vous acceptez notre utilisation de cookies.
